[gdal-dev] Motion: adopt RFC 105: Add and use safe path manipulation functions
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Wed Jan 15 07:19:23 PST 2025
+1
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Even Rouault via gdal-dev
Lähetetty: keskiviikko 15. tammikuuta 2025 17.13
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] Motion: adopt RFC 105: Add and use safe path manipulation functions
HUOM! Viesti on saapunut ulkopuolisesta osoitteesta. Älä avaa viestin linkkejä tai liitteitä, jos et tunnista lähettäjää.
The candidate implementation is now ready (I'm afraid nobody will find the energy to review the ~ 4000 different edits throughout the code base... ) and all CI targets are green. *All* use of the deprecated C versions has been removed from our C++ code (besides the place where they are defined, and autotest code), and the few uses of them in C code is OK. There's no risk of re-introducing them since their definition is now hidden from GDAL C++ code.
So,
Motion: RFC 105 text: Add and use safe path manipulation functions: https://github.com/OSGeo/gdal/pull/11640
Starting with my +1,
Even
http://www.spatialys.com<http://www.spatialys.com/>
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250115/80a643f6/attachment-0001.htm>
