[gdal-dev] Fwd: GDAL open flags
Laurențiu Nicola
lnicola at dend.ro
Thu Jan 16 01:02:50 PST 2025
Hi Michał,
Without knowing a lot about the underlying implementation, I would expect those flags to make no difference in performance. They exist for safety reasons (so you don't modify a dataset by mistake), not as an optimization.
As for the docs, that seems expected. The documentation can't list all the things that a flag does not do.
Laurentiu
On Thu, Jan 16, 2025, at 09:16, Michał Kowalczuk via gdal-dev wrote:
> Any thoughts? :-)
> ---------- Forwarded message ---------
> Od: *Michał Kowalczuk* <michkowalczuk at gmail.com>
> Date: wt., 14 sty 2025 o 12:41
> Subject: GDAL open flags
> To: <gdal-dev at lists.osgeo.org>
> Hi gdal-group!
> Does GDAL_OF_READONLY / GDAL_OF_UPDATE have any impact on performance, especially when reading common vector files (shp, gpkg, gml)? There is no recommendation on this in docs.
> Best regards,
> Michał Kowalczuk
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250116/49b92568/attachment.htm>
