[gdal-dev] Fwd: GDAL open flags
Michał Kowalczuk michkowalczuk at gmail.com
Thu Jan 16 09:10:39 PST 2025
Thank you Laurentiu,
“*They exist for safety reasons (so you don't modify a dataset by mistake),
not as an optimization.” *
This is what I’m looking for. 😊
All the best,
Michal Kowalczuk
W dniu czw., 16 sty 2025 o 10:11 Laurențiu Nicola via gdal-dev <
gdal-dev at lists.osgeo.org> napisał(a):
> Hi Michał,
> Without knowing a lot about the underlying implementation, I would expect
> those flags to make no difference in performance.
> As for the docs, that seems expected. The documentation can't list all the
> things that a flag does not do.
> Laurentiu
> On Thu, Jan 16, 2025, at 09:16, Michał Kowalczuk via gdal-dev wrote:
> Any thoughts? :-)
> ---------- Forwarded message ---------
> Od: *Michał Kowalczuk* <michkowalczuk at gmail.com>
> Date: wt., 14 sty 2025 o 12:41
> Subject: GDAL open flags
> To: <gdal-dev at lists.osgeo.org>
> Hi gdal-group!
> Does GDAL_OF_READONLY / GDAL_OF_UPDATE have any impact on performance,
> especially when reading common vector files (shp, gpkg, gml)? There is no
> recommendation on this in docs.
> Best regards,
> Michał Kowalczuk
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250116/87ef5237/attachment.htm>
