[gdal-dev] Motion: adopt RFC 105: Add and use safe path manipulation functions
Even Rouault even.rouault at spatialys.com
Fri Jan 17 07:40:38 PST 2025
adopted with +1 from PSC members HowardB, JukkaR, KurtS, JavierJS, DanB
and me.
Even
Le 15/01/2025 à 16:13, Even Rouault via gdal-dev a écrit :
> Hi,
> The candidate implementation is now ready (I'm afraid nobody will find
> the energy to review the ~ 4000 different edits throughout the code
> base... ) and all CI targets are green. *All* use of the deprecated C
> versions has been removed from our C++ code (besides the place where
> they are defined, and autotest code), and the few uses of them in C
> code is OK. There's no risk of re-introducing them since their
> definition is now hidden from GDAL C++ code.
> So,
> Motion: RFC 105 text: Add and use safe path manipulation functions:
> https://github.com/OSGeo/gdal/pull/11640
> Starting with my +1,
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250117/732eeeec/attachment-0001.htm>
