[gdal-dev] UTM local correction for height and distance-to-reference-meridian ?
Peter Bennewitz geo25 at pab-opto.de
Mon Jan 20 23:57:51 PST 2025
Dear all,
it's more of an application question than a developer's , - AFAIK there's only
'gdal-dev' ?  Mea culpa if this doesn't belong here.
To get exact distances between local points, UTM requires a correction factor,
depending on local height and distance to the UTM reference meridian. Mainly due
to UTM's 6deg steps, - as opposed to the smaller 3deg of GK, where this
correction could have been neglected. My current idea is be to transform an area
of 10km x 12km to XYZ coordinates that closely match 'field measurable'
distances between two points.
(Pls note that this isn't LatLon<->UTM , for which there are heaps of howto
websites)
What would be the advised way to handle this in GDAL ?  Or a good keyword to
find this in the GDAL doc ?  "local coordinates" maybe ? Or convert the dataset
to the older GK and just use that ?
Any pointers much appreciated, TIA, best,
Peter
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250121/db3f2fb8/attachment.htm>
