[gdal-dev] UTM local correction for height and distance-to-reference-meridian ?
Thomas Knudsen
knudsen.thomas at gmail.com
Tue Jan 21 02:37:59 PST 2025
If you plan to transform to a different system anyway, I would definitely
prefer going to geographical coordinates, and computing the length of the
geodesic between the two points.
First step in converting between a projected system and the earth centered
cartesian XYZ, is using the inverse of the source system, going to
geographical anyway. So the difference in computational cost between a
geodesic and a 3D cartesian computation, will probably be negligible.
Den tirs. 21. jan. 2025 kl. 09.18 skrev Peter Bennewitz via gdal-dev <
gdal-dev at lists.osgeo.org>:
> Dear all,
> it's more of an application question than a developer's , - AFAIK there's
> only 'gdal-dev' ? Mea culpa if this doesn't belong here.
> To get exact distances between local points, UTM requires a correction
> factor, depending on local height and distance to the UTM reference
> meridian. Mainly due to UTM's 6deg steps, - as opposed to the smaller 3deg
> of GK, where this correction could have been neglected. My current idea is
> be to transform an area of 10km x 12km to XYZ coordinates that closely
> match 'field measurable' distances between two points.
> (Pls note that this isn't LatLon<->UTM , for which there are heaps of
> howto websites)
> What would be the advised way to handle this in GDAL ? Or a good keyword
> to find this in the GDAL doc ? "local coordinates" maybe ? Or convert the
> dataset to the older GK and just use that ?
> Any pointers much appreciated, TIA, best,
> Peter
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250121/623136ed/attachment.htm>
