[gdal-dev] Missing GDALMemDataset , GDALDatasetRasterIOEx , VSIMem when GDAL is built with CSHARP Bindings
Paul Harwood runette at gmail.com
Fri Jan 31 05:31:54 PST 2025
I have checked and the three .csproj projects that you listed are NOT
currently being build by the build scripts - because they are not needed
for the test scripts. You will need to build them yourself.
On Fri, 31 Jan 2025 at 13:23, Paul Harwood <runette at gmail.com> wrote:
> The first question that I would ask is what are you trying to achieve?
> DBUILD_APPS=ON will build the standard GDAL apps but does not affect the
> C# trial apps. I think this is the default anyway
> DBUILD_CSHARP_BINDINGS=ON will build the c# bindings and the c# trial
> apps. If that is what you are trying to do this should be sufficient.
> The directory structure is actually dependent on what is created by
> `dotnet` and can vary a little between platforms but sounds about right.
> I have a feeling that when we went to cmake builds, the three apps you
> mentioned mighted have been removed from the build scripts since they are
> not used by the test scripts. I will check but, since they are csproj
> projects you should anyway be able to just build them on top of the
> bindings using `dotnet`.
> On Fri, 31 Jan 2025 at 12:56, Parveen Sharma via gdal-dev <
> gdal-dev at lists.osgeo.org> wrote:
>> Hi
>> I am building GDAL Master branch (
>> https://github.com/OSGeo/gdal/tree/master/swig/csharp/apps) using CMAKE.
>> I am using below flags to build the CSHARP Bindings
>> <arg value="-DBUILD_CSHARP_BINDINGS=ON"/>
>> <arg value="-DBUILD_APPS=ON"/>
>> However,
>>    1. I notice that in "*RelWithDebInfo*" build mode there is NO "*apps*"
>>    folder generated in "RelWithDebInfo\swig\csharp" folder. I do see
>>    individual apps folder like "GDALCreateCopy", "GDALDatasetWrite",
>>    "GDALInfo" generated though. Is this expected?
>>    2. I DO NOT see the any folder corresponding to *GDALMemDataset ,
>>    GDALDatasetRasterIOEx ,  VSIMem *in my "RelWithDebInfo\swig\csharp"
>>    folder even though the source file is present at
>>    https://github.com/OSGeo/gdal/blob/master/swig/csharp/apps/GDALMemDataset.cs
>>    https://github.com/OSGeo/gdal/blob/master/swig/csharp/apps/GDALDatasetRasterIOEx.cs
>>    https://github.com/OSGeo/gdal/blob/master/swig/csharp/apps/VSIMem.cs
>> *Am I missing any additional CMAKE Flags. Can you please let me know?*
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250131/ba62ec6b/attachment.htm>
