[gdal-dev] Missing GDALMemDataset , GDALDatasetRasterIOEx , VSIMem when GDAL is built with CSHARP Bindings
Parveen Sharma
sharma1981 at outlook.com
Fri Jan 31 05:36:15 PST 2025
Thanks
Could you please point me to the relevant scripts?
Sent: Friday, January 31, 2025 9:31 PM
To: Parveen Sharma <sharma1981 at outlook.com>
Cc: Michał Kowalczuk via gdal-dev <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Missing GDALMemDataset , GDALDatasetRasterIOEx , VSIMem when GDAL is built with CSHARP Bindings
I have checked and the three .csproj projects that you listed are NOT currently being build by the build scripts - because they are not needed for the test scripts. You will need to build them yourself.
On Fri, 31 Jan 2025 at 13:23, Paul Harwood <runette at gmail.com<mailto:runette at gmail.com>> wrote:
The first question that I would ask is what are you trying to achieve?
DBUILD_APPS=ON will build the standard GDAL apps but does not affect the C# trial apps. I think this is the default anyway
DBUILD_CSHARP_BINDINGS=ON will build the c# bindings and the c# trial apps. If that is what you are trying to do this should be sufficient.
The directory structure is actually dependent on what is created by `dotnet` and can vary a little between platforms but sounds about right.
I have a feeling that when we went to cmake builds, the three apps you mentioned mighted have been removed from the build scripts since they are not used by the test scripts. I will check but, since they are csproj projects you should anyway be able to just build them on top of the bindings using `dotnet`.
On Fri, 31 Jan 2025 at 12:56, Parveen Sharma via gdal-dev <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>> wrote:
Hi
I am building GDAL Master branch (https://github.com/OSGeo/gdal/tree/master/swig/csharp/apps) using CMAKE. I am using below flags to build the CSHARP Bindings
<arg value="-DBUILD_CSHARP_BINDINGS=ON"/>
<arg value="-DBUILD_APPS=ON"/>
However,
1.
I notice that in "RelWithDebInfo" build mode there is NO "apps" folder generated in "RelWithDebInfo\swig\csharp" folder. I do see individual apps folder like "GDALCreateCopy", "GDALDatasetWrite", "GDALInfo" generated though. Is this expected?
2.
I DO NOT see the any folder corresponding to GDALMemDataset , GDALDatasetRasterIOEx , VSIMem in my "RelWithDebInfo\swig\csharp" folder even though the source file is present at
https://github.com/OSGeo/gdal/blob/master/swig/csharp/apps/GDALMemDataset.cs
https://github.com/OSGeo/gdal/blob/master/swig/csharp/apps/GDALDatasetRasterIOEx.cs
https://github.com/OSGeo/gdal/blob/master/swig/csharp/apps/VSIMem.cs
Am I missing any additional CMAKE Flags. Can you please let me know?
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250131/42ccb976/attachment-0001.htm>
