[gdal-dev] Possible to issue sqlite3_limit with "memory" OGR driver?
Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC]
jesse.r.meyer at nasa.gov
Thu Jul 3 13:14:48 PDT 2025
We’re trying to gdal.Polygonize a feature that exceeds SQLite’s default blob size of 1,000,000,000 bytes. Curiously, we’re using the memory dataset, but this appears to leverage SQLite under the hood (evidenced by the error message: ERROR 1: In GetNextRawFeature(): sqlite3_step() : string or blob too big). SQLite docs state the that limit can be changed at runtime using the sqlite3_limit<https://www.sqlite.org/c3ref/limit.html>(db,SQLITE_LIMIT_LENGTH<https://www.sqlite.org/c3ref/c_limit_attached.html#sqlitelimitlength>,...) interface. Maybe there could be some way to leverage PRELUDE_STATEMENTS to achieve this but we are not “opening” a dataset - we’re creating one directly from the memory driver.
What is the best way to work around this?
Best,
Jesse
Lead Computer Scientist
Science Systems and Applications, Inc.
Dr Compton Tucker Team
NASA Goddard Space Flight Center
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250703/df8d1795/attachment.htm>
