[gdal-dev] Possible to issue sqlite3_limit with "memory" OGR driver?
Even Rouault
even.rouault at spatialys.com
Thu Jul 3 13:23:17 PDT 2025
Jesse,
Maybe you use SQL with the SQLite dialect? Otherwise we lack context to
tell why you get SQLite kicking it.
I don't think sqlite3_limit() would really help you here, givenit can be
used to grow settings beyond the compile time default which is 1 GiB I
believe ("Attempts to increase a limit above its hard upper bound are
silently truncated to the hard upper bound."). You would need to
recompile SQLite itself.
Even
Le 03/07/2025 à 22:14, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND
APPLICATIONS INC] via gdal-dev a écrit :
> We’re trying to gdal.Polygonize a feature that exceeds SQLite’s
> default blob size of 1,000,000,000 bytes. Curiously, we’re using the
> memory dataset, but this appears to leverage SQLite under the hood
> (evidenced by the error message: ERROR 1: In GetNextRawFeature():
> sqlite3_step() : string or blob too big). SQLite docs state the that
> limit can be changed at runtime using the sqlite3_limit
> <https://www.sqlite.org/c3ref/limit.html>(db,SQLITE_LIMIT_LENGTH
> <https://www.sqlite.org/c3ref/c_limit_attached.html#sqlitelimitlength>,...)
> interface. Maybe there could be some way to leverage
> PRELUDE_STATEMENTS to achieve this but we are not “opening” a dataset
> - we’re creating one directly from the memory driver.
> What is the best way to work around this?
> Best,
> Jesse
> Lead Computer Scientist
> Science Systems and Applications, Inc.
> Dr Compton Tucker Team
> NASA Goddard Space Flight Center
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250703/41fbaa50/attachment.htm>
