[gdal-dev] Issues with gdalwarp 3.11.1
    Scott
    public at postholer.com
    Mon Jul  7 09:51:39 PDT 2025
Using GDAL 3.11.1 on Debian 12 proj 9.1.1 and GDAL 3.11.1 on AWS Linux
2, proj 9.2.1, with this source file:
https://water.noaa.gov/resources/downloads/precip/stageIV/2025/07/06/nws_precip_wytd_20250706_conus.tif
This following command fails with 'Warning 1: PROJ: stere: Invalid
latitude':
    gdalwarp -f COG -overwrite -t_srs EPSG:4326
nws_precip_wytd_20250706_conus.tif tst.tif
However, this works fine:
    gdal raster pipeline read nws_precip_wytd_20250706_conus.tif !
reproject --dst-crs EPSG:4326 ! write tst_cli.tif --of=COG --overwrite
If you change the crs to EPSG:3857 or any mercator, gdalwarp doesn't
throw any errors, but gdallocationinfo returns no data:
    gdallocationinfo -l_srs EPSG:4326 -valonly tst.tif -97.4475 29.4843
GDAL CLI works fine for either. gdalwarp 3.9.2 (Debian 12) and 3.7.1
(AWS Linux 2) also work fine.
Thanks!
Scott
www.postholer.com
