[gdal-dev] Issues with gdalwarp 3.11.1
Even Rouault even.rouault at spatialys.com
Mon Jul 7 12:08:53 PDT 2025
Thanks for raising this. Fixed per
https://github.com/OSGeo/gdal/pull/12722 . As that's a rather annoying
regression, I'll likely issue a 3.11.2 RC tomorrow
Even
Le 07/07/2025 à 18:51, Scott via gdal-dev a écrit :
> Using GDAL 3.11.1 on Debian 12 proj 9.1.1 and GDAL 3.11.1 on AWS Linux
> 2, proj 9.2.1, with this source file:
> https://water.noaa.gov/resources/downloads/precip/stageIV/2025/07/06/nws_precip_wytd_20250706_conus.tif
> This following command fails with 'Warning 1: PROJ: stere: Invalid
> latitude':
>    gdalwarp -f COG -overwrite -t_srs EPSG:4326
> nws_precip_wytd_20250706_conus.tif tst.tif
> However, this works fine:
>    gdal raster pipeline read nws_precip_wytd_20250706_conus.tif !
> reproject --dst-crs EPSG:4326 ! write tst_cli.tif --of=COG --overwrite
> If you change the crs to EPSG:3857 or any mercator, gdalwarp doesn't
> throw any errors, but gdallocationinfo returns no data:
>    gdallocationinfo -l_srs EPSG:4326 -valonly tst.tif -97.4475 29.4843
> GDAL CLI works fine for either. gdalwarp 3.9.2 (Debian 12) and 3.7.1
> (AWS Linux 2) also work fine.
> Thanks!
> Scott
http://www.spatialys.com
