[gdal-dev] Gdal raster reproject equivalent to gdalwarp -rpc
Michael Smith
michael.smith.erdc at gmail.com
Fri Jul 18 09:41:20 PDT 2025
>From Frank Wamerdam, the answer is to use --to METHOD=RPC.
And the pipeline would be:
gdal raster pipeline ! read /vsis3/file_P004.NTF ! reproject --to METHOD=RPC ! write /tmp/test2.gdalg.json --overwrite && gdal raster info -f text /tmp/test2.gdalg.json
Mike
Michael Smith
RSGIS Center – ERDC CRREL NH
US Army Corps
On 7/18/25, 11:39 AM, "gdal-dev on behalf of Scott via gdal-dev" <gdal-dev-bounces at lists.osgeo.org <mailto:gdal-dev-bounces at lists.osgeo.org> on behalf of gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>> wrote:
Hey Mike,
For the -rpc option I *think* you can use the -to option in reproject.
Look at the documentation at the link under -to and read that. I *think*
what you're looking for is -to RPC_DEM=pathToDem .
For the pipeline command you can use a gdalg virtual file and "poor
mans" pipeline in bash like:
gdal raster pipeline \
! read some.tif \
! write tmp.gdalg.json --overwrite \
&& gdal raster info tmp.gdalg.json -f text
Hope that helps,
Scott
On 7/18/25 05:05, Michael Smith via gdal-dev wrote:
> All,
> Is there an gdal raster reproject equivalent command to gdalwarp -rpc
> (which we use for NITF files with RPC georeferencing information?
> Additionally, is there a gdal pipeline way to use info as the last step
> rather than writing a file? I would be very useful to be able to do
> gdal raster pipeline ! read example_01_P004.NTF ! reproject --rpc !
> info -f text
> or if there is a stdout/stdin method then gdal raster pipeline ! read
> example_01_P004.NTF ! reproject --rpc ! write <stdout> | gdal raster
> info -f text <stdin>?
> Mike
> Michael Smith
> US Army Corps
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
