[gdal-dev] Gdal raster reproject equivalent to gdalwarp -rpc
Michael Smith michael.smith.erdc at gmail.com
Fri Jul 18 09:41:54 PDT 2025
Frank,
Thanks for that, I can confirm I get the same results with gdalwarp -rpc and gdal raster reproject --to METHOD=RPC. I’ll create a doc ticket to preserve this.
Michael Smith
RSGIS Center – ERDC CRREL NH
US Army Corps
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Frank Warmerdam via gdal-dev <gdal-dev at lists.osgeo.org>
Reply-To: Frank Warmerdam <warmerdam at pobox.com>
Date: Friday, July 18, 2025 at 11:49 AM
To: Scott <public at postholer.com>
Cc: <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Gdal raster reproject equivalent to gdalwarp -rpc
Michael,
If you were depending on -rpc to force use of the RPC method instead of geotransforms for instance, it might be sufficient to pass -to METHOD=RPC to things that take transformer options.
Best regards,
Frank
On Fri, Jul 18, 2025 at 11:39 AM Scott via gdal-dev <mailto:gdal-dev at lists.osgeo.org> wrote:
Hey Mike,
For the -rpc option I *think* you can use the -to option in reproject.
Look at the documentation at the link under -to and read that. I *think*
what you're looking for is -to RPC_DEM=pathToDem .
For the pipeline command you can use a gdalg virtual file and "poor
mans" pipeline in bash like:
gdal raster pipeline \
! read some.tif \
! write tmp.gdalg.json --overwrite \
&& gdal raster info tmp.gdalg.json -f text
Hope that helps,
Scott
On 7/18/25 05:05, Michael Smith via gdal-dev wrote:
> All,
> Is there an gdal raster reproject equivalent command to gdalwarp -rpc
> (which we use for NITF files with RPC georeferencing information?
> Additionally, is there a gdal pipeline way to use info as the last step
> rather than writing a file? I would be very useful to be able to do
> gdal raster pipeline ! read  example_01_P004.NTF ! reproject --rpc !
> info -f text
> or if there is a stdout/stdin method then gdal raster pipeline ! read
> example_01_P004.NTF ! reproject --rpc ! write <stdout> | gdal raster
> info -f text <stdin>?
> Mike
> Michael Smith
> US Army Corps
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
I set the clouds in motion - turn up   | Frank Warmerdam, mailto:warmerdam at pobox.com
light and sound - activate the windows | USA: +1 650-701-7823
and watch the world go round - Rush    | CAN: +1 343-550-9984
_______________________________________________ gdal-dev mailing list gdal-dev at lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/gdal-dev
