[gdal-dev] Understanding parquet vs adbc performance and SORT_BY_BBOX=YES
Even Rouault
even.rouault at spatialys.com
Mon Jul 21 07:13:36 PDT 2025
Le 20/07/2025 à 13:27, Michael Smith via gdal-dev a écrit :
> Using GDAL 3.11.3:
> I have a dataset Geometry: Point Feature Count: 15546949 in parquet
> format (written using gdal from oracle source). When doing a spatial
> query using the geoparquet driver, I see it accessing almost all the
> row groups of the dataset (PARQUET: 155/156 row groups selected) with
> a spatial filter fetching 12000 of the 15M points and it takes
> 0m18.794s. When accessing via ADBC and libduckdb, it takes 0m7.102s
> (but it also uses 7x CPU and about 10x memory (from looking at top).
> I then rewrote the dataset using -lco SORT_BY_BBOX=YES. Then parquet
> driver accesses PARQUET: 9/238 row groups selected, and the time drops
> to 0m1.412s. Using ADBC and libduckdb, the performance doesn’t change.
> For proper performance with gdal, is SORT_BY_BBOX=YES always needed?
yes, unless your features are already spatially sorted. It is a bit
strange that you don't see improvements with the ADBC driver as it does
push the spatial filter bbox in the SQL request, so that's perhaps a
limitation on how duckdb itself deals with such filters
> Michael Smith
> RSGIS Center – ERDC CRREL NH
> US Army Corps
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250721/0e8b626b/attachment.htm>
