[gdal-dev] Understanding parquet vs adbc performance and SORT_BY_BBOX=YES
    Michael Smith
    michael.smith.erdc at gmail.com
    Mon Jul 21 07:33:57 PDT 2025
It was had to really test the ADBC connection as it would crash my cloud instance due to memory / cpu consumption. Doing two map queries at the same time would kill it.
Michael Smith
RSGIS Center – ERDC CRREL NH
US Army Corps
Date: Monday, July 21, 2025 at 10:13 AM
To: Michael Smith <michael.smith.erdc at gmail.com>, <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Understanding parquet vs adbc performance and SORT_BY_BBOX=YES
Le 20/07/2025 à 13:27, Michael Smith via gdal-dev a écrit :
Using GDAL 3.11.3:
I have a dataset Geometry: Point Feature Count: 15546949 in parquet format (written using gdal from oracle source). When doing a spatial query using the geoparquet driver, I see it accessing almost all the row groups of the dataset (PARQUET: 155/156 row groups selected) with a spatial filter fetching 12000 of the 15M points and it takes 0m18.794s. When accessing via ADBC and libduckdb, it takes 0m7.102s (but it also uses 7x CPU and about 10x memory (from looking at top).
I then rewrote the dataset using -lco SORT_BY_BBOX=YES. Then parquet driver accesses PARQUET: 9/238 row groups selected, and the time drops to 0m1.412s. Using ADBC and libduckdb, the performance doesn’t change.
For proper performance with gdal, is SORT_BY_BBOX=YES always needed?
yes, unless your features are already spatially sorted. It is a bit strange that you don't see improvements with the ADBC driver as it does push the spatial filter bbox in the SQL request, so that's perhaps a limitation on how duckdb itself deals with such filters
Michael Smith
US Army Corps
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250721/ee70a16c/attachment.htm>
