[gdal-dev] Timestamp cast error in GDAL Parquet Directory with sqlite dialect
Even Rouault
even.rouault at spatialys.com
Sat Jul 26 12:42:45 PDT 2025
Michael,
are you sure this is the *same* schema ? From the error messages (which
comes from libarrow-compute itself), it would seem there's a mix of
timestamp in microsecond and timestamp in nanosecond, and that the
algorithm in libarrow tries to homogenize things and an overflow occur.
If 237718454400000000 is a timestamp in microseconds, that corresponds
to January 1st 9503... I doubt the SQLite dialect plays any role in that.
Even
Le 26/07/2025 à 20:56, Michael Smith via gdal-dev a écrit :
> I have a collection of parquet files all with the same schema,
> different stac collections written using geopandas to parquet.
> When I query at the cli or in python for a directory of parquert files
> using sql I get timestamp casting errors
> gdal vector info -i PARQUET:s3://mybucket/stac/mds/rasters/ --sql
> "select * from 'rasters' where st_intersects(geometry,
> st_geomfromtext('POLYGON ((-68.00948853933728 17.7602787370086,
> -64.99052950907739 17.7602787370086, -64.99052950907739
> 18.6509945435268, -68.00948853933728 18.6509945435268,
> -68.00948853933728 17.7602787370086))'))" --dialect sqlite -f text
> INFO: Open of `PARQUET:s3://grid-dev-publiclidar/stac/mds/rasters/'
> using driver `Parquet' successful.
> Layer name: SELECT
> Geometry: Polygon
> ERROR 1: ReadNext() failed: Casting from timestamp[us, tz=UTC] to
> timestamp[ns, tz=UTC] would result in out of bounds timestamp:
> 237718454400000000
> Feature Count: 34
> 237718454400000000
> Extent: (-180.000000, -90.000000) - (180.000000, 83.999167)
> If I do it file by file for all the parquet in a directory, I don’t
> get an error.
> Is this a bug or a problem with sqlite dialect and parquet?
> Michael Smith
> RSGIS Center – ERDC CRREL NH
> US Army Corps
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250726/0da4f728/attachment.htm>
