[gdal-dev] Timestamp cast error in GDAL Parquet Directory with sqlite dialect
Michael Smith michael.smith.erdc at gmail.com
Sat Jul 26 11:56:12 PDT 2025
I have a collection of parquet files all with the same schema, different stac collections written using geopandas to parquet.
When I query at the cli or in python for a directory of parquert files using sql I get timestamp casting errors
gdal vector info -i PARQUET:s3://mybucket/stac/mds/rasters/ --sql "select * from 'rasters' where st_intersects(geometry, st_geomfromtext('POLYGON ((-68.00948853933728 17.7602787370086, -64.99052950907739 17.7602787370086, -64.99052950907739 18.6509945435268, -68.00948853933728 18.6509945435268, -68.00948853933728 17.7602787370086))'))" --dialect sqlite -f text
INFO: Open of `PARQUET:s3://grid-dev-publiclidar/stac/mds/rasters/'
      using driver `Parquet' successful.
Layer name: SELECT
Geometry: Polygon
ERROR 1: ReadNext() failed: Casting from timestamp[us, tz=UTC] to timestamp[ns, tz=UTC] would result in out of bounds timestamp: 237718454400000000
Feature Count: 34
Extent: (-180.000000, -90.000000) - (180.000000, 83.999167)
If I do it file by file for all the parquet in a directory, I don’t get an error.
Is this a bug or a problem with sqlite dialect and parquet?
Michael Smith
RSGIS Center – ERDC CRREL NH
US Army Corps
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250726/bab392da/attachment.htm>
