[gdal-dev] multithreading
Javier Jimenez Shaw
j1 at jimenezshaw.com
Tue Jul 29 09:25:21 PDT 2025
Hi
I am running a gdalwarp from UTM xx to EPSG:3857 and later a gdal_translate
to COG (the input is a normal GeoTIFF). Two steps. All inputs and outputs
are TIFF.
Is there any difference between using the config variable
GDAL_NUM_THREADS=ALL_CPUS
than using the creation option for the TIFFs
What is the fastest combination?
Thanks.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250729/bd7e66c9/attachment.htm>
