[gdal-dev] multithreading
Even Rouault even.rouault at spatialys.com
Tue Jul 29 09:30:19 PDT 2025
Javier,
for gdal_translate to COG, both should be equivalent.
for gdalwarp,   -wo NUM_THREADS=ALL_CPUS -co NUM_THREADS=ALL_CPUS (ie
enabling multithreading for warping and GeoTIFF output)   will be
equivalent to --config GDAL_NUM_THREADS=ALL_CPUS
Note that you can also do gdalwarp directly to COG. This should do the
right things
Even
Le 29/07/2025 à 18:25, Javier Jimenez Shaw via gdal-dev a écrit :
> Hi
> I am running a gdalwarp from UTM xx to EPSG:3857 and later a
> gdal_translate to COG (the input is a normal GeoTIFF). Two steps. All
> inputs and outputs are TIFF.
> Is there any difference between using the config variable
> than using the creation option for the TIFFs
> What is the fastest combination?
> Thanks.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
