[gdal-dev] Wrong results during translate input.tif file to output.xyz file with gdal_translate.exe
    Marián Hadri
    Marian.Hadri at rib-software.com
    Mon Jun  2 01:22:43 PDT 2025
Hallo,
I write the same once more, there was a problem with link to my example .
I installed gdal 3.10.2 with gdal_translate.exe as well. I tried to translate the file "input.tif" to the file "output.xyz".
When I did it with ... gdal_translate.exe -of XYZ "input.tif" "output.xyz", I got the file output.xyz which contains
a lot of z-coordinates, like "-3.4028230607370965e+38", which is nonsense, because when I opened this input.tif
file with QGIS, the z-coordinates were in the range "643.2 - 925.2". Could you take a look at this, where is the problem ?
Here is the link with file, which is causing the problems ... https://d.rib-software.com/iTWOI_civil/gdaltmp/input.tif
Thanks in advance, Marian Hadri
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250602/1ea4c9ef/attachment.htm>
