[gdal-dev] Wrong results during translate input.tif file to output.xyz file with gdal_translate.exe
Javier Jimenez Shaw
j1 at jimenezshaw.com
Mon Jun 2 01:25:31 PDT 2025
I still get a 404 response.
On Mon, 2 Jun 2025, 10:23 Marián Hadri via gdal-dev, <
gdal-dev at lists.osgeo.org> wrote:
> Hallo,
> I write the same once more, there was a problem with link to my example .
> I installed gdal 3.10.2 with gdal_translate.exe as well. I tried to
> translate the file "input.tif" to the file "output.xyz".
> When I did it with ... gdal_translate.exe -of XYZ "input.tif" "output.xyz",
> I got the file output.xyz which contains
> a lot of z-coordinates, like "-3.4028230607370965e+38", which is nonsense,
> because when I opened this input.tif
> file with QGIS, the z-coordinates were in the range "643.2 - 925.2". Could
> you take a look at this, where is the problem ?
> Here is the link with file, which is causing the problems ...
> https://d.rib-software.com/iTWOI_civil/gdaltmp/input.tif
> Thanks in advance, Marian Hadri
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250602/b95f72f2/attachment.htm>
