[gdal-dev] [PROPOSAL] Add CADRG write support via RPFTOC/NITF drivers
Patrik Sylve patrik.sylve at t-kartor.com
Wed Jun 11 05:51:48 PDT 2025
We are exploring the possibility of adding write support for CADRG format in GDAL and would appreciate some community feedback before starting implementation.
There is currently no open-source workflow for creating CADRG. GDAL can already read CADRG via RPFTOC/NITF drivers, so extending that work feels like a good next step.
Short background on CADRG format:
CADRG is a Raster Product Format (RPF) that consists of a TOC file referencing data frames. Each data frame is stored as a National Imagery Transmission Format (NITF) message.
GDAL currently supports:
* Reading CADRG (a.toc) via the RPFTOC driver
* Reading individual CADRG frames via the NITF driver
* Writing NITF images, both without and with JPEG compression
To implement a CADRG writer, we could extend the existing NITF and RPFTOC drivers:
NITF:
* Implement Vector Quantisation compression
* Add option to set Frame size
** A CADRG frame must be 1536x1536 pixels, so output would be tiled
* Add option to set CADRG scale
RPFTOC:
* Extend with 'write' mode
** Internally call NITF driver to generate CADRG compliant data frames
** Generate a .toc file per MIL-STD-2411
Example usage, create a CADRG from a TIF-file:
gdal_translate input.tif ./RPF \
    -of RPFTOC \
     -co "PRODUCT=CADRG" \
    # NITF file header options
    -co "FTITLE=My CADRG Product" \
    -co "FSCLAS=U" \
Output:
└── RPF/
├─── a.toc
└─── frames/
├──── 00AVL01C.TL6
└──── 00AVM01C.TL6
Drivers:
* https://gdal.org/en/stable/drivers/raster/rpftoc.html
* https://gdal.org/en/stable/drivers/raster/nitf.html
Standards:
* CADRG: http://everyspec.com/MIL-PRF/MIL-PRF-080000-99999/MIL-PRF-89038_25371/
* RPF: http://everyspec.com/MIL-STD/MIL-STD-2000-2999/MIL-STD-2411_6903/
Would this be a welcomed addition? Any thoughts or feedback is appreciated.
Best regards / Vänliga hälsningar
Patrik Sylve
Software Developer
E: patrik.sylve at t-kartor.com
www.t-kartor.com<http://www.t-kartor.com/>
[cid:465b82b6-444d-4563-8536-8b9cd3b0e8df]
This e-mail is private and confidential between the sender and the addressee. In the event of misdirection, the recipient
is prohibited from using, copying or disseminating it or any information in it. Please notify the above of any such misdirection.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250611/747a23f0/attachment-0001.htm>
Type: image/png
Desc: Outlook-fzlqfxva.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250611/747a23f0/attachment-0001.png>
