[gdal-dev] [PROPOSAL] Add CADRG write support via RPFTOC/NITF drivers
    Even Rouault
    even.rouault at spatialys.com
    Wed Jun 11 07:19:43 PDT 2025
Hi Patrick,
It feels a bit strange that write support for CADRG is needed in 2025,
but besides that, your proposal sounds solid as far as I remember the
details of those formats. I guess the most interesting part will be
write support for vector quantization to figure out the VQ LUT that
minimize loss. Hopefully there is literature on the subject.
Even
Le 11/06/2025 à 14:51, Patrik Sylve via gdal-dev a écrit :
> Hi,
> We are exploring the possibility of adding write support for CADRG
> format in GDAL and would appreciate some community feedback before
> starting implementation.
> There is currently no open-source workflow for creating CADRG. GDAL
> can already read CADRG via RPFTOC/NITF drivers, so extending that work
> feels like a good next step.
> Short background on CADRG format:
> CADRG is a Raster Product Format (RPF) that consists of a TOC file
> referencing data frames. Each data frame is stored as a National
> Imagery Transmission Format (NITF) message.
> GDAL currently supports:
> * Reading CADRG (a.toc) via the RPFTOC driver
> * Reading individual CADRG frames via the NITF driver
> * Writing NITF images, both without and with JPEG compression
> To implement a CADRG writer, we could extend the existing NITF and
> RPFTOC drivers:
> NITF:
> * Implement Vector Quantisation compression
> * Add option to set Frame size
> ** A CADRG frame must be 1536x1536 pixels, so output would be tiled
> * Add option to set CADRG scale
> RPFTOC:
> * Extend with 'write' mode
> ** Internally call NITF driver to generate CADRG compliant data frames
> ** Generate a .toc file per MIL-STD-2411
> Example usage, create a CADRG from a TIF-file:
> gdal_translate input.tif ./RPF \
>     -of RPFTOC \
>      -co "PRODUCT=CADRG" \
> *    # NITF file header options*
>     -co "FTITLE=My CADRG Product" \
>     -co "FSCLAS=U" \
> Output:
> └── RPF/
> ├─── a.toc
> └─── frames/
> ├──── 00AVL01C.TL6
> └──── 00AVM01C.TL6
> Drivers:
> * https://gdal.org/en/stable/drivers/raster/rpftoc.html
> * https://gdal.org/en/stable/drivers/raster/nitf.html
> Standards:
> * CADRG:
> http://everyspec.com/MIL-PRF/MIL-PRF-080000-99999/MIL-PRF-89038_25371/
> * RPF: http://everyspec.com/MIL-STD/MIL-STD-2000-2999/MIL-STD-2411_6903/
> Would this be a welcomed addition? Any thoughts or feedback is
> appreciated.
> Best regards / Vänliga hälsningar
> *Patrik Sylve*
> Software Developer
> *E:***patrik.sylve at t-kartor.com
> www.t-kartor.com <http://www.t-kartor.com/>
> /This e-mail is private and confidential between the sender and the
> addressee. In the event of misdirection, the recipient/
> /is prohibited from using, copying or disseminating it or any
> information in it. Please notify the above of any such misdirection./
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250611/76ca3f8f/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250611/76ca3f8f/attachment-0001.png>
