[gdal-dev] GDALOpenEx() not failing silently
Even Rouault even.rouault at spatialys.com
Sun Jun 29 12:24:19 PDT 2025
you can surround the call to GDALOpenEx() with
CPLPushErrorHandler(CPLQuietErrorHandler);
... GDALOpenEx() here ...
CPLPopErrorHandler();
Le 29/06/2025 à 21:20, Joaquim Manuel Freire Luís via gdal-dev a écrit :
> Hi,
> Again the Julia wrapper. In it to find if a file holds a raster or a
> vector I first open it with GDAL_OF_RASTER and see it the return
> pointer is NULL. This has been working well and SILENTLY when it fail
> (because a OGR vector file name was passed in). But with these
> Meteostat .csv.gz files it fails (expected) but prints an ERROR 1 message.
> The closes (to C and perhaps Python) I can reproduce is this
> julia>
> GMT.Gdal.GDALOpenEx("/vsigzip//vsicurl/https://bulk.meteostat.net/v2/daily/08554.csv.gz",
> GMT.Gdal.GDAL_OF_RASTER, C_NULL, C_NULL, C_NULL)
> ERROR 1: At line 1, did not find X, Y and/or Z values
> Ptr{Nothing} @0x0000000000000000
> All works right, but this error message is annoying (and normal users
> will not understand it).
> Anything I can do to shut it up?
> Joaquim
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250629/3e33e81f/attachment.htm>
