[gdal-dev] GDALOpenEx() not failing silently
    Joaquim Manuel Freire Luís
    jluis at ualg.pt
    Sun Jun 29 12:52:24 PDT 2025
Thanks
Silenced now. But if the GDALOpenEx docs say
Verbose error: GDAL_OF_VERBOSE_ERROR. If set, a failed attempt to open the file will lead to an error message to be reported.
When it is not set (the case here) it should not need this “extra care”, no?
Sent: Sunday, June 29, 2025 8:24 PM
To: Joaquim Manuel Freire Luís <jluis at ualg.pt>; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] GDALOpenEx() not failing silently
you can surround the call to GDALOpenEx() with
CPLPushErrorHandler(CPLQuietErrorHandler);
... GDALOpenEx() here ...
CPLPopErrorHandler();
Le 29/06/2025 à 21:20, Joaquim Manuel Freire Luís via gdal-dev a écrit :
Again the Julia wrapper. In it to find if a file holds a raster or a vector I first open it with GDAL_OF_RASTER and see it the return pointer is NULL. This has been working well and SILENTLY when it fail (because a OGR vector file name was passed in). But with these Meteostat .csv.gz files it fails (expected) but prints an ERROR 1 message.
The closes (to C and perhaps Python) I can reproduce is this
julia> GMT.Gdal.GDALOpenEx("/vsigzip//vsicurl/https://bulk.meteostat.net/v2/daily/08554.csv.gz", GMT.Gdal.GDAL_OF_RASTER, C_NULL, C_NULL, C_NULL)
ERROR 1: At line 1, did not find X, Y and/or Z values
Ptr{Nothing} @0x0000000000000000
All works right, but this error message is annoying (and normal users will not understand it).
Anything I can do to shut it up?
Joaquim
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250629/c3293d90/attachment-0001.htm>
