[gdal-dev] Mute HDF5-DIAG diagnostic output
    Laurențiu Nicola
    lnicola at dend.ro
    Tue Mar  4 00:21:43 PST 2025
PS: the only reference to HDF5's error handling I found while skimming the GDAL code was https://github.com/OSGeo/gdal/blob/0caa252/frmts/hdf5/hdf5vfl.h#L236-L241.
On Tue, Mar 4, 2025, at 10:09, Laurențiu Nicola via gdal-dev wrote:
> Hi Christian,
> On Tue, Mar 4, 2025, at 10:05, Christian Beilschmidt via gdal-dev wrote:
 <https://gis.stackexchange.com/posts/490841/timeline>I tried sending GDAL's error logging to /dev/null but this does not change anything.
> I take it https://docs.rs/gdal/latest/gdal/config/fn.set_error_handler.html doesn't work? Can you try e.g. gdal.PushErrorHandler('CPLQuietErrorHandler') in Python to make sure?
> Laurentiu
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250304/2f60226e/attachment.htm>
