[gdal-dev] Mute HDF5-DIAG diagnostic output
Christian Beilschmidt
christian.beilschmidt at geoengine.de
Tue Mar 4 22:55:59 PST 2025
I tried it with the Python bindings, but there I don't get the
HDF5-DIAG messages
at all.
# Ubuntu 24 LTS version
pip install gdal[numpy]=="3.8.4.*"
*<test.py>*
from osgeo import gdal
gdal.UseExceptions()
dataset = gdal.OpenEx(
"path/to/file.nc",
nOpenFlags=gdal.OF_MULTIDIM_RASTER | gdal.OF_READONLY,
print(dataset.GetDriver().ShortName)
rootGroup = dataset.GetRootGroup()
print(rootGroup.GetGroupNames())
rootGroup.OpenGroup('scenario_6')
*</test.py>*
*<Output>*
netCDF
['scenario_1', 'scenario_2', 'scenario_3', 'scenario_4', 'scenario_5']
File "/examples/hdf5.py", line 14, in <module>
File "/examples/env/lib/python3.12/site-packages/osgeo/gdal.py", line
4088, in OpenGroup
return _gdal.Group_OpenGroup(self, *args)
RuntimeError: Group scenario_6 does not exist
*</Output>*
This is what I would hope for, but it is strange indeed.
Best regards
Christian
Am Di., 4. März 2025 um 09:22 Uhr schrieb Laurențiu Nicola via gdal-dev <
gdal-dev at lists.osgeo.org>:
> PS: the only reference to HDF5's error handling I found while skimming the
> GDAL code was
> https://github.com/OSGeo/gdal/blob/0caa252/frmts/hdf5/hdf5vfl.h#L236-L241.
> On Tue, Mar 4, 2025, at 10:09, Laurențiu Nicola via gdal-dev wrote:
> Hi Christian,
> On Tue, Mar 4, 2025, at 10:05, Christian Beilschmidt via gdal-dev wrote:
> <https://gis.stackexchange.com/posts/490841/timeline>I tried sending
> GDAL's error logging to /dev/null but this does not change anything.
> I take it
> https://docs.rs/gdal/latest/gdal/config/fn.set_error_handler.html doesn't
> work? Can you try e.g. gdal.PushErrorHandler('CPLQuietErrorHandler') in
> Python to make sure?
> Laurentiu
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250305/635e6702/attachment.htm>
