[gdal-dev] Creating Mosaic - Ensuring Maximum Pixel Value is brought forward
Shaima Alsharif salmanami22 at gmail.com
Wed Mar 5 19:29:12 PST 2025
Dear Developers,
I am working on generating a mosaic, and I need to ensure that the maximum
pixel value (dBZ) is selected when merging overlapping raster files.
Despite my attempts using gdalbuildvrt and gdalwarp, I continue to
encounter issues where it does not always pick the maximum pixel value in
overlapping areas.
notes: CRS is EPSG:4326 and GDAL 3.8.5, released 2024/04/02
Commands Used:
1.
gdalwarp -overwrite -multi -r
max  /nfs/radar/max-reflectivity/tiff/raw/*/2025/3/5/20250305T2145*.tif
test-20250305T2145.png.composite.tif
or
gdalbuildvrt test-20250305T2145.png.composite.vrt
gdalwarp -overwrite -q -r max test-20250305T2145.png.composite.vrt
2.
gdaldem color-relief -alpha -q test-20250305T2145.composite.tif \
/color-ramps/reflectivity/titan.txt \ test-20250305T2145.png
*Questions:*
   1. How can I ensure that gdalbuildvrt properly stacks overlapping
   rasters while keeping the maximum pixel values?
   2. Is gdalwarp -r max the correct approach to pick the highest dBZ
   reflectivity values?
Any guidance or suggestions would be greatly appreciated! Thank you in
advance for your help.
With Regards,
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250306/a91d33fe/attachment.htm>
