[gdal-dev] Can we build CSharp Bindings in GDAL v3.9.3 or later with DOT NET FRAMEWORK 4.8?
Parveen Sharma
sharma1981 at outlook.com
Thu Mar 6 00:27:49 PST 2025
Hello
We have a slightly renamed GDAL DLLs for e.g. gdal393.dll and hence the below NuGet packages that are built for .NET Framework won't work with our DLLs.
https://www.nuget.org/packages?q=MaxRev.Gdal
So, Is there a fork for these NUGET Packages which we can look at ?
Best regards,
Sent: Thursday, February 20, 2025 9:40 AM
To: Michał Kowalczuk via gdal-dev <gdal-dev at lists.osgeo.org>; Parveen Sharma <sharma1981 at outlook.com>
Subject: Re: Can we build CSharp Bindings in GDAL v3.9.3 or later with DOT NET FRAMEWORK 4.8?
I would use one of the NuGet packages that are built for .NET Framework
These should suffice, rather than building the bindings yourself.
Cheers,
Ross
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Parveen Sharma via gdal-dev <gdal-dev at lists.osgeo.org>
Sent: Wednesday, 19 February 2025 19:58
Subject: [gdal-dev] Can we build CSharp Bindings in GDAL v3.9.3 or later with DOT NET FRAMEWORK 4.8?
Hello
I am trying to build GDAL CSharp bindings from v3.9.3 branch<https://github.com/OSGeo/gdal/tree/v3.9.3/swig/csharp>.
The documentation for v3.9.3<https://gdal.org/en/stable/api/csharp/csharp_compile_cmake.html#net-build-toolchain> states that it needs .NET 5.0 OR Mono
[cid:459f78aa-7867-445a-8c18-cbdc80f04432]
Question : Is it possible to build GDAL source v3.9.3 using DOT NET Framework 4.8 or less? I am using below flags BUT it seems the build process is attempting to look for only .NET SDK and not the DOT NET FRAMEWORK
<arg value="-DBUILD_CSHARP_BINDINGS=ON"/><!-- C# Bindings-->
<arg value="-DCSHARP_LIBRARY_VERSION=4.8"/>
<arg value="-DCSHARP_APPLICATION_VERSION=4.8"/>
Does GDAL still support building CSharp Bindings with .net framework?
Please let me know.
Best regards,
Parveen
Caution: Please do not click links or open attachments unless you recognise the sender and know the content is safe.
This email and any files transmitted with it may be confidential and are intended solely for the use of the individual or entity to whom they are addressed. Any confidentiality is not waived or lost because this email has been sent to you by mistake. This email may contain personal information of individuals, and be subject to Commonwealth and/or State privacy laws in Australia. This email is also subject to copyright. If you are not the intended recipient, you must not read, print, store, copy, forward or use this email for any reason, in accordance with privacy and copyright laws. If you have received this email in error, please notify the sender by return email, and delete this email from your inbox.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250306/061746d7/attachment-0001.htm>
Type: image/png
Desc: image.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250306/061746d7/attachment-0001.png>
