[gdal-dev] FlatGeobuf Layer vs Feature Columns
    Patrick Young
    patrick.mckendree.young at gmail.com
    Thu Mar  6 15:39:37 PST 2025
Hello,
I translated some geojson to flatgeobuf where the geojson features have a
variable number of properties (e.g. some features have a bunch of
translations for the name of a place pulled from OSM).
I noticed in the ogrinfo output that while the summary info has all the
fields possible,
name:ar: String (0.0)
name:bn: String (0.0)
...etc...
each feature prints out just its actual fields associated with it:
OGRFeature(layer):1
  name (String) = Huselva
  LINESTRING (-36.7425039 -54.1973051 ...etc..)
I had expected a bunch of NULL values for all the fields not set, much like
what QGIS shows or what happens if I translate to e.g. geoparquet.
In the flatgeobuf spec, I noticed it supports a per feature schema
https://github.com/flatgeobuf/flatgeobuf/blob/3d488b384a911b3a18d8b28ee730fb8f3831a39b/src/fbs/header.fbs#L75
Is ogr taking advantage of this? Or is it just aware that those fields were
never set for that feature?
I am asking because if I was to create the flatgeobuf directly with OGR, I
am not sure if I need to call CreateField on the layer itself for all
possible fields, or can I do something per feature?
Thanks!
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250306/e395c7dd/attachment.htm>
