[gdal-dev] FlatGeobuf Layer vs Feature Columns
Scott public at postholer.com
Thu Mar 6 15:46:24 PST 2025
If your using ogr2ogr try using the switch -emptyStrAsNull if you're not.
On 3/6/25 15:39, Patrick Young via gdal-dev wrote:
> Hello,
> I translated some geojson to flatgeobuf where the geojson features have
> a variable number of properties (e.g. some features have a bunch of
> translations for the name of a place pulled from OSM).
> I noticed in the ogrinfo output that while the summary info has all the
> fields possible,
> name:ar: String (0.0)
> name:bn: String (0.0)
> ...etc...
> each feature prints out just its actual fields associated with it:
> OGRFeature(layer):1
>    name (String) = Huselva
>    LINESTRING (-36.7425039 -54.1973051 ...etc..)
> I had expected a bunch of NULL values for all the fields not set, much
> like what QGIS shows or what happens if I translate to e.g. geoparquet.
> In the flatgeobuf spec, I noticed it supports a per feature schema
> https://github.com/flatgeobuf/flatgeobuf/
> blob/3d488b384a911b3a18d8b28ee730fb8f3831a39b/src/fbs/header.fbs#L75
> <https://github.com/flatgeobuf/flatgeobuf/
> blob/3d488b384a911b3a18d8b28ee730fb8f3831a39b/src/fbs/header.fbs#L75>
> Is ogr taking advantage of this? Or is it just aware that those fields
> were never set for that feature?
> I am asking because if I was to create the flatgeobuf directly with OGR,
> I am not sure if I need to call CreateField on the layer itself for all
> possible fields, or can I do something per feature?
> Thanks!
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
