[gdal-dev] GeoTIFF: "SetDataAxisToSRSAxisMapping" effect on (consistency between) "GDALGetGeoTransform"
Even Rouault even.rouault at spatialys.com
Fri Mar 14 08:59:09 PDT 2025
Ramon,
Tricky subject,
in theory the geotransform should be interpreted by taking into account
the DataAxisToSRSAxisMapping value (GDAL will never change the order of
coefficients within the geotransform), but I'm afraid there's quite
substantial code in GDAL that neglects to do it properly, and so the
best is to stick with the OAMS_TRADITIONAL_GIS_ORDER, otherwise you're
going to run into troubles. In https://github.com/OSGeo/gdal/pull/11622
there was some work to make the GDALTransformer logic aware of
DataAxisToSRSAxisMapping through a new transformer option, but it is
only set by the new method GDALDataset::GeolocationToPixelLine()
function, and not by the warp logic for example.
Even
Le 14/03/2025 à 16:48, Ramon Antonio via gdal-dev a écrit :
> Dear Community,
> Does SetDataAxisToSRSAxisMapping have any effect on GDALGetGeoTransform?
> In other words, if the axis order is changed, should the order of
> geotransform coefficients also change, automatically or manually?
> More details on the question are posted here:
> https://gis.stackexchange.com/questions/491133/gdal-geotiff-consistency-between-gdalgetgeotransform-and-setdataaxistosrsaxi
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
