[gdal-dev] GeoTIFF: "SetDataAxisToSRSAxisMapping" effect on (consistency between) "GDALGetGeoTransform"
    Ramon Antonio
    antonio.rrz at gmail.com
    Fri Mar 14 09:37:37 PDT 2025
Even,
Thanks for the prompt response!
You don't mind if you or I post your answer on gis.stackexchange with
credit to you?
On Fri, Mar 14, 2025 at 6:59 PM Even Rouault <even.rouault at spatialys.com> wrote:
> Ramon,
> Tricky subject,
> in theory the geotransform should be interpreted by taking into account
> the DataAxisToSRSAxisMapping value (GDAL will never change the order of
> coefficients within the geotransform), but I'm afraid there's quite
> substantial code in GDAL that neglects to do it properly, and so the
> best is to stick with the OAMS_TRADITIONAL_GIS_ORDER, otherwise you're
> going to run into troubles. In https://github.com/OSGeo/gdal/pull/11622
> there was some work to make the GDALTransformer logic aware of
> DataAxisToSRSAxisMapping through a new transformer option, but it is
> only set by the new method GDALDataset::GeolocationToPixelLine()
> function, and not by the warp logic for example.
> Even
> Le 14/03/2025 à 16:48, Ramon Antonio via gdal-dev a écrit :
> > Dear Community,
> > Does SetDataAxisToSRSAxisMapping have any effect on GDALGetGeoTransform?
> > In other words, if the axis order is changed, should the order of
> > geotransform coefficients also change, automatically or manually?
> > More details on the question are posted here:
> > https://gis.stackexchange.com/questions/491133/gdal-geotiff-consistency-between-gdalgetgeotransform-and-setdataaxistosrsaxi
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
