[gdal-dev] GTI: override SRS of source tiles (disable reprojection)
    Even Rouault
    even.rouault at spatialys.com
    Wed Mar 19 02:24:58 PDT 2025
Craig,
> Is there a way to override the projection of the source tiles when
> using the GTI driver?
One way would be to put in the GTI index
"vrt:///path/to/file?a_srs=srs_def" where srs_def is an EPSG code or a
WKT string (cf
https://gdal.org/en/stable/drivers/raster/vrt.html#vrt-connection-string)
Even
http://www.spatialys.com
