[gdal-dev] GTI: override SRS of source tiles (disable reprojection)
Scott
public at postholer.com
Tue Mar 18 18:34:49 PDT 2025
If your rasters are invalid with bad projections or unreadable by
gdalinfo, disregard the following.
One way to create massive tile index's with individual rasters having 2
or more different projections is to use good old gdaltileindex. It will
create an index of tiles (raster files) and bounding box geometry in a
specified EPSG without altering the underlying raster projection. Such as:
gdaltindex
-lyr_name bbox
-tileindex file
-t_srs EPSG:4326
result.fgb rast_3857.tif rast_4269.tif
The bbox geometry column will be 4326, regardless of what the raster is.
The above will create a tile index in FlatGeobuf format. FGB is
important because now you can grab a bbox of only the rasters you need.
Your client/user will still have to deal with the different projections
of each raster in the index.
While GTI can also use FGB, gdaltileindex with FGB is a bit more
lightweight. You can do lots of flexible, non-standard things by adding
meta data (or whatever) for each tile. Here's a write-up and working
example using 1 FGB tile index, 514 COG's and a LeafLet client:
https://www.postholer.com/fgbcog/
Hope that helps!
Scott
On 3/18/25 17:13, Craig de Stigter via gdal-dev wrote:
> Hi folks
> I'm working on converting an existing VRT mosaic pipeline to use GTI to
> improve its scalability with huge layers.
> A problem is that our individual raster tiles may have projections with
> subtly varying WKT, since they were often produced by customers using
> different tooling and in different places. The WKT in the tiles may even
> be altogether incorrect or missing (even though they're actually all the
> same projection as the GTI file itself).
> With VRT this was not a problem since the VRT file didn't support
> reprojection and just overrode the projection of its tiles. But with GTI
> I think the driver is unnecessarily passing everything through the warp
> kernel.
> Is there a way to override the projection of the source tiles when using
> the GTI driver?
> Regards,
> Craig
> Platform Engineer
> Koordinates
> koordinates.com <http://koordinates.com/> / @koordinates <https://
> twitter.com/koordinates>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
