[gdal-dev] Building GDAL with rtree support
    Jon Morris
    Jon.Morris at jbarisk.com
    Thu May 15 07:58:27 PDT 2025
Confirming that installing sqlite to /usr/local instead of /usr/local/install-sqlite-trusted-schema-off and just overwriting the system sqlite fixes the problem.
Jon
e: Jon.Morris at jbarisk.com
d:+44 (0)1756 587229
t: +44 (0)1756 799919
www.jbarisk.com
All JBA Risk Management's email messages contain confidential information and are intended only for the individual(s) named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system.
JBA Risk Management Limited is registered in England, company number 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North Yorkshire, BD23 3FD, England.
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Jon Morris via gdal-dev
Sent: 15 May 2025 12:25
To: gdal dev <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Building GDAL with rtree support
CAUTION: This email originated from outside of JBA and contains one or more links and one or more attachments. DO NOT click links or open attachments unless you recognise the sender's email address and are absolutely certain that the content is safe.
See the Phishing page on IMS on SP for more information about how to spot and report suspicious messages.
WARNING: This email contains one or more attachments with links within the attachment(s). Please take extra care when handling the attachments.
Hi Jukka,
If I just run sqlite3 on the command line (/usr/local/bin/sqlite3) then ENABLE_RTREE is not there, but if I run the version I compiled, /usr/local/install-sqlite-trusted-schema-off/bin/sqlite3, then it is.
I suspect one of the downstream dependencies is using the wrong version of sqlite but I'm pretty sure I've specified the correct one for proj, spatialite, and gdal.
The sqlite build step has been copied from https://github.com/OSGeo/gdal/blob/master/.github/workflows/ubuntu_20.04/Dockerfile.ci#L247 - is there a good reason to configure with --prefix=/usr/local/install-sqlite-trusted-schema-off rather than just replacing the sqlite in /usr/local/bin?
Jon
e:
Jon.Morris at jbarisk.com<mailto:Jon.Morris at jbarisk.com>
d:
+44 (0)1756 587229
t:
+44 (0)1756 799919<tel:+44%20(0)1756%20799919>
www.jbarisk.com<http://www.jbarisk.com/>
[cid:image001.png at 01DBC5B2.31357880]
[cid:image002.png at 01DBC5B2.31357880]
[cid:image003.png at 01DBC5B2.31357880]<https://www.linkedin.com/company/jba-risk-management/>
[cid:image004.png at 01DBC5B2.31357880]<https://www.youtube.com/channel/UC0iatom2jYbW96voW0rlpCw>
-----Original Message-----
From: Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>>
Sent: 15 May 2025 12:16
To: gdal dev <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>>; Jon Morris <Jon.Morris at jbarisk.com<mailto:Jon.Morris at jbarisk.com>>
Subject: Re: Building GDAL with rtree support
CAUTION: This email originated from outside of JBA and contains one or more links. DO NOT click links unless you recognise the sender's email address and are absolutely certain that the content is safe.
If you suppose that rtree is missing, compile only SQLite and then run this in SQLite
pragma compile_options;
It should show "ENABLE_RTREE".
If that is ok then the error happens in some other place.
-Jukka-
________________________________________
Lähettäjä: gdal-dev käyttäjän Jon Morris via gdal-dev puolesta
Lähetetty: Torstai 15. toukokuuta 2025 13.37
Vastaanottaja: gdal dev
Aihe: [gdal-dev] Building GDAL with rtree support
Hello all, I'm trying to build GDAL python wheels and am having some autotest fails that is preventing the build. I think most if not all of these fails are due to rtree not being available in sqlite. AFAIK I've done everything needed but the build recipe must be missing something. The dockerfile contents are below and I run it with the command `DOCKER_BUILDKIT=0 docker build -f Dockerfile -t gdal-wheelbuilder`. It gets as far as `ctest -V` then exits with the following test fails: 46 - autotest_gdrivers (Failed) 48 - autotest_ogr (Failed) 50 - autotest_pyscripts (Failed) Thanks, Jon FROM quay.io/pypa/manylinux_2_28_x86_64 # Arrow install instructions from https://arrow.apache.org/install/RUN dnf update -y \ && dnf groupinstall -y "Development Tools" \ && dnf install -y epel-release \ && dnf install -y https://dl.fedoraproject.org/pub/epel/epel-release-latest-$(cut -d: -f5 /etc/system-release-cpe | cut -d. -f1).noarch.rpm \ && dnf install -y https://packages.apache.org/artifactory/arrow/almalinux/$(cut -d: -f5 /etc/system-release-cpe | cut -d. -f1)/apache-arrow-release-latest.rpm \ && dnf config-manager --set-enabled epel \ && dnf config-manager --set-enabled powertools \ && dnf install -y arrow-devel \ && dnf install -y arrow-dataset-devel \ && dnf install -y parquet-develRUN dnf install -y \ ant \ autoconf \ automake \ bash-completion \ cmake \ ca-certificates \ ccache \ clang \ cmake \ curl-devel \ doxygen \ git \ gnupg \ gpsbabel \ lcov \ hdf5-devel \ json-devel \ json-c-devel \ libaec-devel \ libdeflate-devel \ libjpeg-devel \ libkml-devel \ libpng-devel \ libpq-devel \ libtiff-devel \ libtool \ libwebp-devel \ libxml2-devel \ libzstd-devel \ make \ minizip-devel \ numactl \ openssl-devel \ openjpeg2-devel \ pkg-config \ poppler-devel \ postgresql \ postgresql-contrib \ python3-devel \ python38-devel \ python3-lxml \ python3-numpy \ python3-pip \ python3-pytest \ python3-setuptools \ python3-virtualenv \ swig \ unzip \ wget \ zip \ zlib-devel # Install geosRUN mkdir -p /src \ && cd /src \ && curl -f -L -O https://download.osgeo.org/geos/geos-3.13.0.tar.bz2 \ && tar jxf geos-3.13.0.tar.bz2 \ && cd /src/geos-3.13.0 \ && mkdir build \ && cd build \ && cmake -DCMAKE_INSTALL_PREFIX=/usr -DBUILD_TESTING=OFF -DCMAKE_BUILD_TYPE=Release .. \ && make -j$(nproc) \ && make install \ && cd / \ && rm -rf /src # Build a SQLite version with -DSQLITE_TRUSTED_SCHEMA=0RUN mkdir sqlite \ && wget -q https://sqlite.org/2023/sqlite-autoconf-3430100.tar.gz -O - \ | tar xz -C sqlite --strip-components=1 \ && cd sqlite \ && CFLAGS="-O2 -DSQLITE_TRUSTED_SCHEMA=0 -DSQLITE_ENABLE_COLUMN_METADATA -DSQLITE_ENABLE_RTREE" ./configure --prefix=/usr/local/install-sqlite-trusted-schema-off \ && make -j$(nproc) \ && make -j$(nproc) install \ && cd .. \ && rm -rf sqlite # Fix proj versionRUN mkdir -p /src \ && cd /src \ && curl -f -L -O https://download.osgeo.org/proj/proj-9.1.1.tar.gz \ && tar xzf proj-9.1.1.tar.gz \ && cd /src/proj-9.1.1 \ && mkdir build \ && cd build \ && cmake -DEXE_SQLITE3=/usr/local/install-sqlite-trusted-schema-off/bin/sqlite3 .. \ && cmake --build . \ && cmake --build . --target install \ && rm -rf /src # Build libgeotiff (system libgeotiff pulls in system libproj as a dependency)RUN mkdir -p /src \ && cd /src \ && curl -f -L -O https://github.com/OSGeo/libgeotiff/releases/download/1.7.3/libgeotiff-1.7.3.tar.gz \ && tar xzf libgeotiff-1.7.3.tar.gz \ && cd libgeotiff-1.7.3 \ && mkdir build_autoconf \ && cd build_autoconf \ && export LD_LIBRARY_PATH=/usr/local/lib64:/usr/local/lib:/usr/lib:/lib \ && CFLAGS="-Wall -Wextra -Werror" ../configure \ && make -j$(nproc) \ && make check \ && cd .. \ && mkdir build_cmake \ && cd build_cmake \ && cmake -DCMAKE_C_COMPILER_LAUNCHER=ccache -DCMAKE_C_FLAGS="-Wall -Wextra -Werror" .. \ && make -j$(nproc) \ && rm -rf /src # Build freexl (spatialite dependency)RUN mkdir -p /src \ && cd /src \ && curl -f -L -O https://www.gaia-gis.it/gaia-sins/freexl-2.0.0.tar.gz \ && tar xzf freexl-2.0.0.tar.gz \ && cd /src/freexl-2.0.0 \ && ./configure \ && make -j$(nproc) \ && make install \ && rm -rf /src # Build spatialite so it uses correct PROJ and sqlite3RUN mkdir -p /src \ && cd /src \ && curl -f -L -O https://www.gaia-gis.it/gaia-sins/libspatialite-sources/libspatialite-5.1.0.tar.gz \ && tar xzf libspatialite-5.1.0.tar.gz \ && cd /src/libspatialite-5.1.0 \ && SQLITE3_CFLAGS="-I/usr/local/install-sqlite-trusted-schema-off/include/" SQLITE3_LIBS="-Wl,--enable-new-dtags,-rpath=/usr/local/install-sqlite-trusted-schema-off/lib -L/usr/local/install-sqlite-trusted-schema-off/lib -lsqlite3" ./configure --disable-rttopo \ && make -j$(nproc) \ && make install \ && rm -rf /src # configure shared librariesRUN ldconfig -v # Add GDAL source to container# and checkout current branch and commit (see README.md).# Also patch in commits https://github.com/OSGeo/gdal/commit/b36072fa1539b8ac97ea7864071d3468ac5b49ab# and https://github.com/OSGeo/gdal/commit/222e1c111437f9fd6e43eb384f0903684735750b to get rid of# arrow/parquet deprecation warningsARG GITHUB_WORKSPACE=/src RUN mkdir -p $GITHUB_WORKSPACE \ && cd $GITHUB_WORKSPACE \ && git config --global user.email you at example.com<mailto:you at example.com> \ && git config --global user.name "Your Name" \ && git clone -b release/3.10 https://github.com/OSGeo/gdal.git superbuild \ && cd superbuild \ && git checkout 9b7a7c8 \ && git cherry-pick b36072fa \ && git cherry-pick 222e1c11 # Install test requirementsRUN python3.8 -m pip install -U pip setuptools numpy importlib_metadata \ && python3.8 -m pip install -r $GITHUB_WORKSPACE/superbuild/autotest/requirements.txt ## This section based on build-linux-ubuntu-focal job in .github/workflows/cmake_builds.yml ## ARG CMAKE_UNITY_BUILD=OFF # - name: ConfigureRUN set -eu \ && cd $GITHUB_WORKSPACE/superbuild \ && export CXXFLAGS="-march=native -O2 -Wodr -flto-odr-type-merging -Werror" \ && export CFLAGS="-O2 -march=native -Werror" \ && mkdir build \ && cd build \ && cmake .. \ -Werror=dev \ -DCMAKE_INSTALL_PREFIX=$GITHUB_WORKSPACE/install-gdal \ -DCMAKE_UNITY_BUILD=${CMAKE_UNITY_BUILD} \ -DGDAL_USE_PUBLICDECOMPWT:BOOL=ON \ -DPUBLICDECOMPWT_URL=https://github.com/rouault/PublicDecompWT \ -DWERROR_DEV_FLAG="-Werror=dev" \ -DPython_LOOKUP_VERSION=3.8 \ -DUSE_CCACHE=OFF \ -DCMAKE_INTERPROCEDURAL_OPTIMIZATION=ON \ -DGDAL_USE_TIFF_INTERNAL=ON \ -DGDAL_USE_GEOTIFF_INTERNAL=ON \ -DSQLite3_INCLUDE_DIR=/usr/local/install-sqlite-trusted-schema-off/include \ -DSQLite3_LIBRARY=/usr/local/install-sqlite-trusted-schema-off/lib/libsqlite3.so \ -DBUILD_CSHARP_BINDINGS:BOOL=OFF \ && unset CXXFLAGS \ && unset CFLAGS # - name: BuildRUN GIT_LFS_SKIP_SMUDGE=1 cmake --build $GITHUB_WORKSPACE/superbuild/build -- -j$(nproc) # - name: test (with command targets)RUN cmake --build $GITHUB_WORKSPACE/superbuild/build --target quicktest -- -j$(nproc) # - name: test (with ctest)RUN cd $GITHUB_WORKSPACE/superbuild/build \ && ctest -V # - name: installRUN cmake --build $GITHUB_WORKSPACE/superbuild/build --target install -- -j$(nproc) ## END build-linux-ubuntu-focal job in .github/workflows/cmake_builds.yml ## Jon MorrisSoftware Developer-- e: Jon.Morris at jbarisk.comd:+44<mailto:Jon.Morris at jbarisk.comd:+44> (0)1756 587229t: +44 (0)1756 799919www.jbarisk.com[X][X][X][X]   All JBA Risk Management's email messages contain confidential information and are intended only for the individual(s) named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. JBA Risk Management Limited is registered in England, company number 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North Yorkshire, BD23 3FD, England.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250515/5de8bb98/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250515/5de8bb98/attachment-0008.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250515/5de8bb98/attachment-0009.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250515/5de8bb98/attachment-0010.png>
Type: image/png
Desc: image004.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250515/5de8bb98/attachment-0011.png>
Type: image/png
Desc: image017610.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250515/5de8bb98/attachment-0012.png>
Type: image/png
Desc: image639965.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250515/5de8bb98/attachment-0013.png>
Type: image/png
Desc: image116692.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250515/5de8bb98/attachment-0014.png>
Type: image/png
Desc: image104301.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250515/5de8bb98/attachment-0015.png>
