[gdal-dev] How to set the _FillValue with CreateCopy?
    Joaquim Manuel Freire Luís
    jluis at ualg.pt
    Sat May 17 03:02:03 PDT 2025
In Julia I use this function to create data cubes.  It works fine
https://github.com/GenericMappingTools/GMT.jl/blob/master/src/gdal_utils.jl#L866
but all my attempts to set the _FillValue (and the 'actual_range' btw) have failed. Last attempt shows up still as commented lines.
So my question is how to set them.
Thanks
Joaquim
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250517/e155b889/attachment.htm>
