[gdal-dev] Not writing PAM files
Andrew C Aitchison
andrew at aitchison.me.uk
Mon Nov 3 08:14:44 PST 2025
On Mon, 3 Nov 2025, Javier Jimenez Shaw via gdal-dev wrote:
> Hi
> When I read some raster files (in particular thermal JPEG files), a side
> car file .aux.xml appears next to it.
> I would like to avoid the creation of this side car file, but I want to use
> any .aux.xml file if it is already there. Yes, I could imagine there is a
> performance impact if I read it several times, but I am going to read the
> file only once.
> The config option GDAL_PAM_ENABLED seems to be completely disabling PAM
> functionality:
> https://gdal.org/en/stable/user/configoptions.html#persistent-auxiliary-metadata-pam-options
> Reading the documentation, I would imagine that the PAM is completely
> disabled, not only the creation of the side car file while reading a raster.
> Is it posible to not create the .aux.xml, but use it if present?
I see that Even has just added a patch specifically for dji images.
in general, one other option might be to not give the running process
write permission on the directory (perhaps with a read-only (re)mount) ?
Andrew C. Aitchison Kendal, UK
