[gdal-dev] Not writing PAM files
Even Rouault even.rouault at spatialys.com
Mon Nov 3 08:19:19 PST 2025
FLIR should be fined. It has a "PamFlagKeeper oKeeper(nPamFlags);" guard
that makes sure to restore the PAM flags to its initial value after
metadata has been set
Le 03/11/2025 à 17:08, Javier Jimenez Shaw a écrit :
> Thank you Even!
> Probably the same is needed for FLIR, as DJI logic was based in FLIR
> code also in jpgdataset.cpp
> On Mon, 3 Nov 2025 at 17:04, Even Rouault <even.rouault at spatialys.com>
> wrote:
>     Hi Javier,
>     .aux.xml file is no longer generated on opening per
>     https://github.com/OSGeo/gdal/commit/2ad4ebf4ddcaa74af2d4cea212fb61f0ac382f20
>     Even
>     Le 03/11/2025 à 10:13, Javier Jimenez Shaw via gdal-dev a écrit :
>     > Hi
>     > When I read some raster files (in particular thermal JPEG files), a
>     > side car file .aux.xml appears next to it.
>     > I would like to avoid the creation of this side car file, but I
>     want
>     > to use any .aux.xml file if it is already there. Yes, I could
>     imagine
>     > there is a performance impact if I read it several times, but I am
>     > going to read the file only once.
>     > The config option GDAL_PAM_ENABLED seems to be completely disabling
>     > PAM functionality:
>     https://gdal.org/en/stable/user/configoptions.html#persistent-auxiliary-metadata-pam-options
>     > Reading the documentation, I would imagine that the PAM is
>     completely
>     > disabled, not only the creation of the side car file while
>     reading a
>     > raster.
>     > Is it posible to not create the .aux.xml, but use it if present?
>     > Thank you
>     > _______________________________________________
>     > gdal-dev mailing list
>     > gdal-dev at lists.osgeo.org
>     > https://lists.osgeo.org/mailman/listinfo/gdal-dev
>     http://www.spatialys.com
>     My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251103/cce505e1/attachment.htm>
