[gdal-dev] Build issues in Linux, gnu GCC 8.5.0
Ivan Lucena
ivan.lucena at outlook.com
Fri Nov 14 10:34:01 PST 2025
Hi folks,
I build GDAL 3.12 in Linux using GCC 8.5 and got 3 instance of "unique_ptr of a forward-declared class".
It wasn't a big problem to solve, as you can see in the "git diff" report below.
I am not sure but it seems like that issue should be resolved by updating the compile too.
Anyway, for folks that might have that same problem, all I had to do is to add the following "#include" statements.
It should be harmless. Everything seems to be working fine.
Best regards,
Ivan
$ git diff
diff --git a/apps/gdalalg_vector_pipeline.h b/apps/gdalalg_vector_pipeline.h
index 87ed7c045c..ed44fdb513 100644
--- a/apps/gdalalg_vector_pipeline.h
+++ b/apps/gdalalg_vector_pipeline.h
@@ -22,6 +22,8 @@
#include <map>
#include <vector>
+#include "memdataset.h"
//! @cond Doxygen_Suppress
diff --git a/frmts/vrt/vrtdataset.h b/frmts/vrt/vrtdataset.h
index bcc4d30790..677b23d398 100644
--- a/frmts/vrt/vrtdataset.h
+++ b/frmts/vrt/vrtdataset.h
@@ -24,6 +24,8 @@
#include "gdal_vrt.h"
#include "gdal_rat.h"
+#include "gdalpansharpen.h"
#include <atomic>
#include <deque>
#include <functional>
diff --git a/gcore/gdal_multidim.h b/gcore/gdal_multidim.h
index 8c5d9f9037..7c45a76f41 100644
--- a/gcore/gdal_multidim.h
+++ b/gcore/gdal_multidim.h
@@ -25,6 +25,8 @@
#include <memory>
#include <vector>
+#include "gdal_rat.h"
/* Multidimensional array API */
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251114/18807863/attachment-0001.htm>
