[gdal-dev] Working with gdal mdim
Scott
public at postholer.com
Fri Nov 14 12:17:03 PST 2025
Greetings,
With gdal mdim convert, is it possible to get subsets using a time range
with GRIB? Also, should I be concerned with these errors? The data
source is a GRIB/GRIdded Binary (.grb, .grb2), using GDAL v3.12.0
Getting valid time slices remotely works fine. Part of the output is
shown. Note, this file changes frequently, so the times may be different
if you run this command:
gdal mdim info
/vsicurl/https://tgftp.nws.noaa.gov/SL.us008001/ST.opnl/DF.gr2/DC.ndfd/AR.conus/VP.001-003/ds.qpf.bin
--array TIME --detailed
"unit": "sec UTC",
"values": [1763164800, 1763186400, 1763208000, 1763229600,
1763251200, 1763272800, 1763294400, 1763316000, 1763337600, 1763359200,
1763380800]
Converting to .tif using a single time slice, I get this error, but
resulting file seems to be OK. If I download the entire ds.qpf.bin first
and run with the local file, no errors.
gdal mdim convert
tst.tif --subset 'TIME("1763164800")' --array QPF_0-SFC --co
COMPRESS=DEFLATE --overwrite --quiet
ERROR 1: JSON parsing error: continue (at offset 0)
Trying to get a range of subsets based on time always fails. Is getting
a range like this correct/possible?
gdal mdim convert ds.qpf.bin tst.tif --subset
'TIME("1763164800,1763251200")' --array QPF_0-SFC --co COMPRESS=DEFLATE
--overwrite
ERROR 1: Non numeric bound in subset specification.
Thanks for any help!
Scott
