[gdal-dev] gdal raster color-map segfault
Even Rouault
even.rouault at spatialys.com
Wed Nov 19 01:59:34 PST 2025
fix in https://github.com/OSGeo/gdal/pull/13445 . Do not hesitate to
directly file github tickets for such obvious issues
Even
Le 19/11/2025 à 05:10, Scott via gdal-dev a écrit :
> Greetings,
> Putting a hex color in a color-map.txt file causes a segfault. No, you
> shouldn't be doing that. GDAL 3.12.0. Here's an example:
> gdal raster color-map \
> -i byte.tif \
> --color-map bad-color-map.txt \
> -o tst.png --overwrite
> bad-color-map.txt:
> nv 255 255 255 255
> 0 88 0 0
> 128 #ffccff
> 255 0 0 88
> Thanks!
> Scott
http://www.spatialys.com
