[gdal-dev] Trailing null in XML metadata in GMLJP2
Brad Hards bradh at frogmouth.net
Wed Nov 19 16:56:55 PST 2025
It looks like there is a trailing null in the character data written inside the XML box in JPEG
2000 (only tested with OpenJPEG).
I'm seeing a validation error in jpylyzer about not well formed XML, which I think is
probably related to this. Or at least goes away with this change:
*diff --git a/gcore/gdaljp2metadata.cpp b/gcore/gdaljp2metadata.cpp*
*index 439b7e6625..a247cad9f8 100644*
*--- a/gcore/gdaljp2metadata.cpp*
*+++ b/gcore/gdaljp2metadata.cpp*
@@ -3333,7 +3333,7 @@
GDALJP2Metadata::CreateGDALMultiDomainMetadataXMLBox(GDALDataset *poSrcDS,
    GDALJP2Box *poBox = new GDALJP2Box();
    poBox->SetType("xml "); -    poBox->SetWritableData(static_cast<int>(strlen(pszXML) + 1),
+    poBox->SetWritableData(static_cast<int>(strlen(pszXML)),
                           reinterpret_cast<const GByte *>(pszXML));
    CPLFree(pszXML);
However that +1 looks deliberate. So is that trailing null intentional, in that its required for
some interoperability or backwards compatibility reason, even though it isn't strictly
allowed in XML?
Brad
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251120/881a62a4/attachment.htm>
