[gdal-dev] gdal raster calc - a modulo operator (%)?
Javier Jimenez Shaw j1 at jimenezshaw.com
Tue Oct 7 10:14:57 PDT 2025
Just for the record, "mod" of a floating point number should be properly
documented.
On Tue, 7 Oct 2025, 18:53 Daniel Baston via gdal-dev, <
gdal-dev at lists.osgeo.org> wrote:
> It's fairly straightforward to define functions in C++ and register them
> with muparser. You can see how we do this with "isnan" and "isnodata" here:
> https://github.com/OSGeo/gdal/blob/ca7a2d38893a8d6cdc03653b47712f4442d99d65/frmts/vrt/vrtexpression_muparser.cpp#L27
> I don't think we want too many custom functions, but adding "mod" seems
> like a good idea.
> Dan
> On Tue, Oct 7, 2025 at 12:30 PM Scott via gdal-dev <
>> Greetings!
>> I've been unable to find a modulo operator in CLI calc. It's not in the
>> muparser functions or appear to be in the forth-coming 3.12 C pixel
>> functions.
>> This has been working with muparser, but it's messy every time you need
>> a simple modulo. pixel is real or int, div is int:
>> rint(pixel) - (rint(rint(pixel) / div) * div)
>> Am I missing something? If not, consider this a feature request! :)
>> Thanks!
>> Scott
>> www.postholer.com
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251007/d016110d/attachment.htm>
