[gdal-dev] gdal raster calc - a modulo operator (%)?
Scott
public at postholer.com
Tue Oct 7 14:24:26 PDT 2025
Thanks for the idea Dan. Building on that, I added it upstream to the
MuParser source. Now I have it in libmuparser as well:
./muparser-2.3.5/include/muParserTemplateMagic.h
static T Mod(T pixel, T div) { return lround(pixel) -
((lround(pixel) / lround(div)) * lround(div)); }
./muparser-2.3.5/src/muParser.cpp
DefineFun(_T("mod"), MathImpl<value_type>::Mod);
After rebuild, leads to:
gdal raster calc \
--input "p=input.tif" \
--calc="mod(p[1], 50) == 0 ? p[1] : 255" \
--ot=Byte \
--output="output.tif" --co COMPRESS=DEFLATE --overwrite --progress
Ideally, though, having a mod function in GDAL itself would be awesome.
Scott
On 10/7/25 09:52, Daniel Baston wrote:
> It's fairly straightforward to define functions in C++ and register them
> with muparser. You can see how we do this with "isnan" and "isnodata" here:
> https://github.com/OSGeo/gdal/blob/
> ca7a2d38893a8d6cdc03653b47712f4442d99d65/frmts/vrt/
> vrtexpression_muparser.cpp#L27 <https://github.com/OSGeo/gdal/blob/
> vrtexpression_muparser.cpp#L27>
> I don't think we want too many custom functions, but adding "mod" seems
> like a good idea.
> Dan
> On Tue, Oct 7, 2025 at 12:30 PM Scott via gdal-dev <gdal-
> dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>> wrote:
> Greetings!
> I've been unable to find a modulo operator in CLI calc. It's not in the
> muparser functions or appear to be in the forth-coming 3.12 C pixel
> functions.
> This has been working with muparser, but it's messy every time you need
> a simple modulo. pixel is real or int, div is int:
> rint(pixel) - (rint(rint(pixel) / div) * div)
> Am I missing something? If not, consider this a feature request! :)
> Thanks!
> Scott
> www.postholer.com <http://www.postholer.com>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/gdal-dev <https://
> lists.osgeo.org/mailman/listinfo/gdal-dev>
