[gdal-dev] mdim: BLOCKSIZE creation syntax is not array-specific?
Michael Sumner
mdsumner at gmail.com
Fri Oct 10 01:45:51 PDT 2025
Ah, very good, exactly what I need. Thanks Even.
On Fri, Oct 10, 2025 at 11:29 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi Michael,
> Blocksize creation option should be bound to a dimension specifically?
> yes, you can do that with something like: ARRAY:IF(DIM=2):BLOCKSIZE=256,256
> See
> https://gdal.org/en/stable/api/gdalgroup_cpp.html#_CPPv4N9GDALGroup8CopyFromERKNSt10shared_ptrI9GDALGroupEEP11GDALDatasetRKNSt10shared_ptrI9GDALGroupEEbR7GUInt64K7GUInt6416GDALProgressFuncPv12CSLConstList
> Even
> Cheers, Mike
> Michael Sumner
> Ordinary Member, Streets People Love Hobart Association
> Research Software Engineer
> Australian Antarctic Division
> Hobart, Australia
> 0438489030
> e-mail: mdsumner at gmail.com
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
Michael Sumner
Hobart, Australia
0438489030
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251010/857a21f0/attachment.htm>
