[gdal-dev] [ogr2ogr] Anti-meridian issue when reprojecting from a Polar Stereographic projection to a geographic CRS
Andrey VI
andrey_vi at list.ru
Tue Oct 14 05:50:11 PDT 2025
Hello.
I can't reproject data from a Polar Stereographic projection (EPSG:3996) to a geographic projection (EPSG:4326) correctly using ogr2ogr. Command:
ogr2ogr -t_srs EPSG:4326 -wrapdateline polys_4326.shp polys.shp
ERROR 1: IllegalArgumentException: Points of LinearRing do not form a closed linestring
As a result some polygons are broken and also some polygons appears with artifacts.
The data used and the result (58 MB): https://drive.google.com/file/d/176jtROjjeTlAQTITAJ75tBT1GwiUzSUm/view?usp=sharing .
How to reproject from a projection naturally crossing the anti-meridian to a geographic CRS without any errors using ogr2ogr?
Andrey
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251014/1db5ff8b/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251014/1db5ff8b/attachment-0001.png>
