[gdal-dev] Trying to build plugins
Howard Butler
howard at hobu.co
Wed Oct 15 11:12:23 PDT 2025
> On Oct 15, 2025, at 1:02 PM, David Klaus via gdal-dev <gdal-dev at lists.osgeo.org> wrote:
> I believe in the past I ran into an issue where I couldn't confirm through gdalinfo.exe whether or not a format was available in my build. After some looking around, I realized that some formats were only listed via ogrinfo.exe. Sorry if you already know this or if this information isn't 100% accurate. But, hopefully this helps you,
For historical reasons, OGR ~= vector and GDAL ~= raster. These have been more closely unified in the new GDAL CLI – try issuing 'gdal --formats' or 'gdal --formats --json' for a unified set (GDAL 3.11+)
Howard
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251015/9b61844a/attachment.htm>
