[gdal-dev] Trying to build plugins
David Days
david.days at maplarge.com
Wed Oct 15 11:18:30 PDT 2025
David and Howard--that definitely helps. If I pick the right command for
the --formats call, it shows exactly what was expected when the driver is
available. [insert facepalm]
That helps with the core issue of the required support. I'm still open to
suggestions about having the plugins show up. It's not central now, but I
can see that coming back around to being important some day.
I really appreciate the fast replies, from both--thanks!
David
On Wed, Oct 15, 2025 at 2:12 PM Howard Butler <howard at hobu.co> wrote:
> On Oct 15, 2025, at 1:02 PM, David Klaus via gdal-dev <
> gdal-dev at lists.osgeo.org> wrote:
> I believe in the past I ran into an issue where I couldn't confirm through
> gdalinfo.exe whether or not a format was available in my build. After some
> looking around, I realized that some formats were only listed
> via ogrinfo.exe. Sorry if you already know this or if this information
> isn't 100% accurate. But, hopefully this helps you,
> For historical reasons, OGR ~= vector and GDAL ~= raster. These have been
> more closely unified in the new GDAL CLI – try issuing 'gdal --formats' or
> 'gdal --formats --json' for a unified set (GDAL 3.11+)
> Howard
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251015/1920e6ca/attachment-0001.htm>
